Holiday Rambler '87
Discussion in 'Full Timing' started by Gacres, Oct 22, 2007.
  1. Gacres
    Gacres New Member
    My Acu Guage above the door has a Chassis button and a coach button. The Chassis button will not light up and therefore will not me allow to start the vehicle. I have put in a new battery and still nothing. Does anyone know what the problem could be?
  2. Guest
    RE: Holiday Rambler '87
    It could be the switch itself or maybe the seleniod that is powered by the switch??
    Do u hear a click when u hit the switch???
    If not then it be a selenoid problem..
    Please post back on u'r findings :)
  3. Kirk
    Re: Holiday Rambler '87
    I would locate the isolation solenoid and wire around it first and see if that doesn't work. If it does, then trouble shoot the isolation solenoid.
  4. s.harrington
    Sounds like the latching solenoid is bad.
