inverter question
Discussion in 'RV Tips & Tricks' started by levoyb, Mar 13, 2010.
  1. levoyb
    levoyb New Member
    Question about inverter. If connected to shore power does it(shore power) charge my house battery and should my inverter be turned off? The folks at the rv place have me all confused. I understand the inverter converts 12 volt to 110, and converter(sp) converts 110 to 12 volt for lights, etc. So I would think generally the inverter would be switched off most of the time. Is that correct? Sorry to be so long, any help would be appreciated.
  2. chief4-1
    chief4-1 New Member
    RE: inverter question
    Yes, your correct. Your inverter would be off unless you needed to convert 12 volt to 110.
  3. Clay L
    Clay L Senior Member
    Re: inverter question
    To answer the second question, yes the converter does charge the house batteries.
    In some cases it also charges the engine battery. Some Fleetwood products have that feature. I think it is not a common feature however.
