inverter question
Discussion in 'Beginning RVing' started by larryccf1, Aug 7, 2008.
  1. larryccf1
    larryccf1 New Member
    as some may have read in the class B forum, i'm planning on building a class B van
    only area i'm fairly weak in is electrical power draws - i've found DC to AC power inverters that will deliver 900Watts of 120V
    i was thinking to install two 100 amp hour deep cycle batteries, the sprinter dodge van has an auxiliary battery isolater and disconnect as an option, as well as a 220 amp alternator.
    will i be able to run a small coffee maker, 700 watt microwave or a tv (LCD) when parked with no generator running, and if so, for how long? don't plan on using all three at same time but for instance, the TV, without knowing the current draw, but using my desktop computer as a ref, it's drawing .9 amp 120V) - how long would those two batteries support TV useage before having to turn generator on?
    tks
  2. larryccf1
    RE: inverter question
    wow, kind of feel like i posted on a foriegn language board in the wrong language
    for those that read and are curious on the info - i forgot, a friend of mine is an electrical engineer (in fact he mfgrs a ultra-sound tank monitor for RVs as well as a circuit board that monitors battery voltage and starts the generator when batteries go too low)
    the answer, everything seems to be measured in wattage, that watts are the same no matter the voltage, so a 100 amp hour 12V battery (in ideal conditions) will have 1200 watts at full charge.
    A 19" Samsung LCD tv draws 50 watts, so theoretically the battery will support the TV for 24 hours useage.
    Inverter suffers efficiency loss, as do other items in the system, but still, i'm safe assuming 4-6 hours of TV time plus a pot of coffee, off one battery. If i install two batteries, i'm good to go for the above and overnight useage on the refrig, furnance, whatever.
  3. DL Rupper
    Re: inverter question
    Duh, huh :clown: Those of us that read are just RVers. Sounds like you already had the answer. I'm impressed. :laugh:
  4. elkhartjim
    elkhartjim Senior Member
    Wonder if he was checking us or his electrical engineering friend? Inquirying minds always want to know.
  5. TexasClodhopper
    I thought we answered somewhere else on the forum. Did you post in two places?
  6. dbl-d
    dbl-d New Member
    Didn't realize we needed an engineering degree to own an RV. Maybe I better rethink getting one. :laugh:
  7. C Nash
    Glad I didn't post an answer :laugh:
  8. cwishert
    cwishert New Member
    What??????????? :clown:
