Iota converters in a Jayco
Discussion in 'General RVing' started by s.harrington, Sep 13, 2006.
  1. s.harrington
    I'm working on a Jayco 5th with 2 DLS-45 converters hooked together at a j-block. I've never seen this type of a configuration before. Both units went bad within 10 days of each other. I'm wondering if the two units were causing back feed to each other and shortened the life. Anyone ever have this type of problem before? :question: :question: :question:
  2. Poppa
    Poppa Member
    Re: Iota converters in a Jayco
    My limited experience would have me believe you are correct, escecially if they are feeding the same circuitry. I have not seen this done before :question: :question:
  3. s.harrington
    Called Iota and they said it was OK. They have large diodes to keep it from getting backfeed.
