lights?????????
Discussion in 'Towables' started by infinity22, Nov 3, 2007.
  1. infinity22
    infinity22 New Member
    first of all great forum and second i'm new to the rv'ing. i just bought a 92 28' terry fifth wheel and noticed when i plug it in to the house none of the lights inside the fifth wheel work. if i start the truck everything eventually works. i know some of the lights are run off the battery but when plugged in it shouldn't matter. i'm confused. :(
  2. hertig
    Re: lights?????????
    Sounds like your batteries are low, and your 'converter' (which provides 12v and battery charging from 120v) is not working adequately. Then when the truck is running that charging circuit the batteries charge and the lights work.
  3. infinity22
    Re: lights?????????
    thanks for the reply. where would i look for the converter??
  4. hertig
    Re: lights?????????
    In my 2001 Terry, it was under the sink. attached to the wall. Usually they are near the master circuit panel. Often they have a fan on them, so sometimes you can find them by following the fan noise.
