looking for rv
Discussion in 'Class A / Diesel Pushers' started by terry n, Aug 17, 2009.
  1. terry n
    terry n New Member
    I'm looking for a 30' or less class a diesel pusher. Musts - diesel generator, air brakes and suspension, strong or large motor capable of pulling 30' enclosed race car trailer, allison tranny, 22.5 tires. Wants - single slide, jake brake, would like the rear axle to be as close to rear of coach as possible. I would like the smaller coach for ease of track side manuvering. Can anyone tell me if this exists. Any other suggestions would be appreciated.
  2. Shadow
    Shadow Senior Member
    RE: looking for rv
    You could try pplmotorhomes for grins.
  3. Guest
    RE: looking for rv
    well i had one ,, but 40ft ,, with tags ,, but had all that u want and more ,, even did some engine mods ,, great pulling power up hills ,, but the black smoke was kinda a bummer to the others ,, but not me ,, when that black smoke rolled ,, i was smiling from ear to ear ,,,, gonna really mis that :( :(
  4. C Nash
    Re: looking for rv
    Rod just add you a jug filled with trans fluid and line to the intake so you can open a valve and add all the smoke out back you want. Woops giving out one of my secrete weapons for back in the good ole days :eek: :laugh: . Hard to follow or catch you with a smoke cloud behind you. Only problem Rod with that is it;ll be blue smoke :(
  5. TexasClodhopper
    Re: looking for rv
    Chelse, I always wanted to do that just for tailgaters. You know, the ones that draft behind you, and you can only see them if you 'wiggle' them into a side mirror.
  6. C Nash
    Re: looking for rv
    It'll get them off your tail Tex because they cant see you. Amazing how much smoke a little trans fluid will sen out the tailpipe. Now before all you tree huggers get after me naw don't do those crazy things anymore. Wife settled me down 50 yr ago. In fact 50th is coming up next month :eek:
  7. cwishert
    cwishert New Member
    Re: looking for rv
    I am sure you have not helped the OP in this thread. He did not need to know how to smoke out tailgaters. You should have at least pointed him to Ken or someone to help him out. At least Butch gave him a little help. :cool: :clown:
  8. C Nash
    Re: looking for rv
    Well Carol or John you have been here enough to know that we do tend to get off the subject :) when we know nothing off the OP we tend to keep the post current until someone that has an answer post. Did yours help the OP :laugh: ;) But see it's still up so maybe someone can help. Sorry Terry but it does keep your post current.
  9. terry n
    terry n New Member
    RE: looking for rv
    No problem. I guess I really should weigh my trailer. We travel all over the southeast racing and I would like to get a MH and I really don't think a gas burner would work if for no other reason the fuel economy. I may be wrong but I'm guessing a diesel would get around 8-10 with plenty of power and a gas motor (V-10 or 8.1) would be around 5. I've also been told that the diesels are built on stronger chassis'. Like I said I'm just looking for opinions and maybe someone to set the facts straight if I'm incorrect.
  10. H2H1
    Re: looking for rv
    well Terry I get 7.6 to 8.3 mpg on my gasser and it is a 8.i Chevy. I do have the banks exhaust with a super chip installed and that helped. But as you know diesel are designed to pull more load and for on the road more than a gasser. Good luck on your decision.
  11. cwishert
    cwishert New Member
    Re: looking for rv
    Chelse, my post was in fun also. I was just making a point. Terry we have a 29' Gas Chevy with the 6.0 motor, we get about 11 miles to the gallon but I am sure it would not pull what you are talking about. Maybe look into a Toy hauler or a Motor Toter. I wish I could afford one of those. :cool:
  12. cwishert
    cwishert New Member
    Re: looking for rv
    Guess I should change my signature as everyone knows John can't even turn the computer on. Only the one he uses to diagnose vehicle problems with. It has a cute name Darby (DRB). :eek: :laugh: or something like that. One day he said he would bring Darby home, I asked does she do housework? :clown: :clown: :laugh:
  13. TexasClodhopper
    Re: looking for rv
    Terry, my Winnie gasser gets around 8 mpg if I drive 60 mph and use the Plus grade of gasoline.
  14. elkhartjim
    elkhartjim Senior Member
    Re: looking for rv
    On a 2000 miles + trip to Yellowstone from Texas, I averaged 9.3 mpg, 38' DP pulling a 2008 Toyota Avalon on a tow dolly at 1900 rpms. I try to drive watching the rpm's rather than the speedometer unless of course I need to obey the posted speed limits. That didn't make any sense, of course you have to obey the speed limits. I hope I didn't get too far off topic.
  15. C Nash
    Re: looking for rv
    Carol I took it as a joke but it was a good question and I just thought it was a good time to explain that sometimes I do just add crazy answers to keep a post alive. I knew that Terry was a racer or figured he was by his post so most all us racer are kind of wierd anyway :laugh:
    Terry I have the V10 Ford (ouch) I'm a chevy person and I think you would be much better off with a diesel. Just be sure that even the diesel has enough for the total weight. If you were just doing local tracks maybe a gasser. Most of the gasser are limited to around 5000k tow that I have seen. Sure there are some with more
  16. H2H1
    Re: looking for rv
    hey Jim. I run my gasser about 20-2100 rpm and that will give 60-65 mph. But sometime going down hill I will get up to 68 mph all the time getting about 7+ MPG. Get this last year in NM going down a long hill I 13 mpg, now that was good, never ever got that again.I do wish I could get 9 mpg, do you think it would help if I use premium gas other than just regular gas? :laugh: :laugh: :laugh: :laugh:
  17. elkhartjim
    Re: looking for rv
    Tex apparently thinks so...he is using premium.
  18. TexasClodhopper
    Re: looking for rv
    I know that the middle grade improves mine. I have detailed records where I proved it to myself. I've never had the guts to use premium, but I know that regular is way too low octane for my V-10.
    Your mileage will vary.
  19. elkhartjim
    Re: looking for rv
    Dang it. Regular, plus , premium. I get confused. I want to go back to regular and ethyl. And for you youngsters, ethyl is not the lady next door.
  20. TexasClodhopper
    Re: looking for rv
    Ethyl was the wife that got 'flashed' in Ray Steven's song "The Streak". Remember "You get your clothes on, you hussie!" :clown:
    (I guess we've only been of minimal help to the OP, but we did try. :laugh: )
