lowering my hi lo
Discussion in 'Talkback' started by gwilliams1957, May 20, 2007.
  1. gwilliams1957
    gwilliams1957 New Member
    I have a Hi Lo towlite. For some reason I cannot get it lower. The battery is charged. Does anyone have any ideas Thanks
  2. hertig
    Re: lowering my hi lo
    What does it do when you try to lower it? Does it try and fail, or just ignore you?
    If the former, then perhaps there is something blocking it from coming down, or something jamming the mechanism. If the latter, it is probably not getting power. Check any fuses first, and then start tracing the circuit with a voltage meter.
  3. C Nash
    Need a little more info such as do you hear a hum, click or anything? As John said there could be fuses or some safety device if everything is not in order before lowering. Most likely a fuse, switch, wire or motor. Get out the VM and start checking and let us know.
    Welcome to the forum
