Making Onboard Generator Quieter Outside
Discussion in 'RV Tips & Tricks' started by Wolfpack Fan, Jul 13, 2012.
  1. Wolfpack Fan
    Wolfpack Fan Junior Member
    We tailgate a lot during college football season. Before we got our little Yamaha ef2000 (super quiet) we used the onboard Onan Marquis 7000. It provided plenty of power, but since the tailgating activity was going on right around the motor home is was a little loud. On a whim I got an idea to lay a rug under the generator on top of the pavement. It made quite a difference in the sound level. I'm not a sound engineer, but I think the rug absorbed a lot of the sound that would normally radiate off of the hard surfaced pavement. We started doing the same thing camping. The rug we used is heavy rubber backed like the ones a lot of business have changed out regularly by linen companies. A couple of times I added another rug under the mh between the generator and the side where we were partying. I created ripples in the rug and that made even more difference.
  2. C Nash
    Thats interesting Wolfpack fan. Thanks
  3. H2H1
    I will try that next time I have to use our portable one, the MH has a 5500 onan and like the 7700 it is load to me, but not to the wife.
  4. Philip.Saran
    Philip.Saran Junior Member
    If you don't already use a exhaust extension for your on board generator, you might want to look
    at that, it routes the exhaust up above the MH and that should also cut down on the noise and it
    also gets the exhaust smell away from people.
  5. H2H1
    I had the extended exhaust made from a muffler shop and it does do the job. We use it at NASCAR races
  6. iona.head
    iona.head Junior Member
    Simple solution for problem. Thanks for posting Wolfpack Fan I will try this in my MH.
