elkhartjim - 6/6/2010 10:04 AM
I haven't been here for awhile but had to get in on this.
Would it be yes, yes, could be, no, yes, the other side, yes, no, no, on the roof near the center, the white switch, under the bed, 20 quarts. I hope this helps.
You cannot verify the water level of the radiator by looking at the overflow bottle. You must remove the radiator cap and check the water level from there. Be sure to fill the radiator to the overflow outlet before replacing the cap. Always, always use diesel anti-freeze.... Anti-freeze for gas engine's will ruin a diesel engine.sket - 6/6/2010 1:13 PM On th right side sitting in the drivers set, there is a light (red) it states "do not move coach" while driving down the road it blinks on and off sometimes ?The only ""do not move coach"" light that I have is when the Air Brake is set.The water light left and low of the brake light on the dash blinks on and off sometimes while driving ?
