Re: New to RVing
TomPilot,
That is one tough question, however Kirk gave you some good advice. I would not leave home without surge protection and he has that on his list and is readily available after market. I went with a Progressive EMS system.
Things that I had that I did not like. (PLEASE remember "I Had" are the operative words with emphasis on I). J-Lounge (did not see the utility, I like second reg couch or recliners); Booth Dinette (I'm not a big guy (165 lbs) but I felt the table was way too close to me); TV over the driver (too much craning of the noggin. Present M/H has it in the salon and I prefer this); Gas oven (prefer convection/micro combo); I'm sure I will think of more.
Reason this is tough don't know if you are buying new or used. If used I'm sure tires, maintenance records, manuals, third party inspection etc would make the list.
Things I might add to Kirks list. washer/dryer (vented); I'm a big fan of fantastic vents though most coaches come with at least one; If you have a pass through compartment a slide tray would be nice; dash fans assist defroster in keeping windshields fog free; macerator or sanicon sure helps in emptying tanks;
Also in your intial post you mentioned 33-36 ft range. I have never owned a 33 ft M/H but I have ridden in a neighbors 32 foot M/H and it is not as good a ride as the longer homes. You get a bit of porposing with shorter wheel bases. So please take that into consideration when looking and test driving. Also I have found most dealers or parties selling M/H show you the home all opened up (slides out). Make sure to look at the puppy buttoned up you may find you can't open the refrig or get to bathroom without crawling over everything (both of those were show stoppers with my better 90%).
I'm sure many more smarter folks than I will respond.
Good luck in search.
Very Respectfully,
Jeff
GO NAVY!!!!!!
