Howdy everyone, new here. Found the site while trying to get repair info for my "new" 1991 Fleetwood Bounder 28T, 1990 Chevy Chassis, 454. Got it free from a cousin, outside looks bad, faded, a few problems with exterior doors, to be expected. Had to replace fuel pump, ended up mainly being hose from pump up had slit in it, and rats got to the wires. As we've been trying to get it ready to try and use, we've found fridge doesn't want to work, seems it's not getting any propane (burners won't light on stove) even though gauges show it at 1/2 tank, won't run on electric either? Water pump leaking, and leak in wall behind galley sink, appears to be at drain, slows down after sink stops running, stops even while under pressure. Did get the coach running after the fuel pump deal, also had to add a ground to it, wire seemed to not be doing it's job, spliced one in to the frame. She also gave us her 1995 Geo Tracker 2x4 to pull around behind it, "if" we can get her to be roadworthy. Tracker is in excellent shape. Any ideas, suggestions? :blackeye:
