Newbie question
Discussion in 'Beginning RVing' started by cooneyjr, Jul 28, 2007.
  1. cooneyjr
    cooneyjr New Member
    Hello to all I am on my first camping trip in my new used travel trailer. It is a Cherokee 27l and my Expedition seem to pull it fine. Everything seem to work fine on the camper except one of the pleated light filtering blinds it is a double blind you can pull one down to filter light or the 2nd one down over it to filter out more light. The problem is when you put them in the up position
    they just slide rite back down and do not stay up. how do I adjust this blind so it will stay up?
    Butch
  2. Bush70
    Bush70 New Member
    Re: Newbie question
    you need to tighten the strings on either side. Tighten them and you are in bussiness. Good luck
  3. cooneyjr
    cooneyjr New Member
    RE: Newbie question
    Thanks when I get home I will tighten them.
    Butch
  4. hertig
    Re: Newbie question
    For future referance, they are called 'day/night blinds'
  5. TexasClodhopper
    Re: Newbie question
    Butch, be very careful when you tighten the string. It is just cotton and it will break. There are two short springs in the top bar that is holding the tension on each side. On mine you run your blind up 5 or 8 inches from the bottom, grab one side string, and pull down to stretch the spring some more. Then you make another wrap on a stationary knob at the end of the string.
    The trouble is that the knob's diameter on mine represents about an inch of string length, and the springs in the top quickly reached their max "stretch". That only leaves the string to stretch, and cotton string doesn't stretch very far. My experience with the strings is with the new replacement blinds I got, and in disecting the "old" ones.
    On our Winnebago the string in one of the blinds just broke while we were driving down the road. Winnebago replaced both blinds without even a whimper and over the telephone, too!
  6. cooneyjr
    cooneyjr New Member
    RE: Newbie question
    Thanks I will be going home after while and I will let you know I am famous for breaking stuff so I can use the tip.
    Thanks again
    Butch
  7. ARCHER
    ARCHER Senior Member
    Re: Newbie question
    Hey Tex, how did Winnebago get thru that telephone line to replace your blinds. Did they take the broken ones back thru the same telephone line? I bet they whimpered when they were squeezing thru that telephone line....... :laugh: :laugh:
  8. DL Rupper
    Re: Newbie question
    My 12 year old Hitchhiker II has gone through about 7 different day/night shade strings breaking. The hard part is getting somebody with enough smarts to fix them. most blind companies won't touch them. I've spent enough (approximately $50/shade) to buy all new ones, but when it happens 1 at-a-time, it's easier/cheaper to just get it repaired when or if you can.
  9. Bush70
    Bush70 New Member
    Re: Newbie question
    If you need to fix a blind again go to dirtyblindman.com. He will sell you the kit for about $20 with step by step instructions. It is not that hard to do your self.
    Good Luck
  10. TexasClodhopper
    Re: Newbie question
    ARCHER, I got me one 'o dem hi-spid lins! Kin squirt a lot'o stuf tru der! I kint wate fer da frig ta go out!
  11. ARCHER
    Re: Newbie question
    Sure would be something to see.....fridge...... ;)
