Grandview Trailer Sa
OK, here is the scoop on Norcold's Recall of their Refrigerators. Gonna try to make this easy to understand. Wish me luck.
Cooling Unit Replacement Recall
On TWO door Models (Norcold recall #02E-19) Vehicle model years 1999 - 2000
Models: N841 - N821 - N621 and 1082
Cooling Unit Serial Numbers: 1038000 to 1099000
Remedy: Replace Cooling Unit
On FOUR door Models (Norcold recall #02E-045) Vehicle model years 1997 - 2000
Models: 1200LR and 1200LRIM
Cooling Unit Serial Numbers: 700000 to 1008700
Thermal Switch Kit retrofit Recall - Extended Recall I
Four Door Models (Norcold Recall #08E-030 Vehicle model years 1999 - 2002
Models: 1200LR, 1200LRIM and 1201LRIM
Cooling Unit Serial Numbers: 1008701 - 1273700
Remedy: Install a Thermal Switch Kit
Thermal Switch Ket retrofit Recall - Extended Recall II
Four door Models (Norcold Recall #09E - 027) Vehicle model years 2001 - 2003
Cooling Unit Serial Numbers: 1273701 to 1536607
NOW,to quotethe certified Letter I recieved the other day:
Norcold recall NHTSA assigned the number 10E-049 for all 1200, 1201, 1210 and 1211 Refers. with serial numbers from 315525 to 13088811.
This recall supersedes previous Norcold Recalls 02E-045, 08E-30, 09E-026 and 09E-027 and extends the affected population to include units manufactured as of Oct. 7th, 2010. It will involve retrofitting refrigerators of affected models with a new thermocouple high temperature sensing system.
Norcold has decided that a defect which relates to motor vehicle safety exists in certain 1200, 1201, 1210 and 1211 model gas/elec. refrigerators should be recalled......................Therefore, the recall poulation will include all refrigerator models 1200, 1201, 1210 and 1211 with cooling unit serial numbers from 700000 to 13085759, non consecutively, manufactured between December 1996 and Oct. 6, 2010. These Refrigerators should be retrofitted using Norcold part number #634737 RECALL KIT. end quote
SO, if you have a TWO door refer. newer than a 2000 year model, you don't have anything to worry about, but if you have a FOUR door refer, check it out!!! Hope this helps. Kenneth
