Onan fuel problem
Discussion in 'Talkback' started by indy, Mar 21, 2007.
  1. indy
    indy New Member
    My 5.0 BGA Onan has an aftermarket fuel pump. When it runs for more than a few minutes it seems to flood the carburetor and the engine dies. Carb rebuild kits are no longer available. When I clamp the hose between the pump and carb to restrict the fuel I can get it to run ok. Before I buy a new carb, could the fuel pump be too strong or does the carb float seat need to be replaced?
    I purchased it used. We use it around the farm.
    Thanks in advance for advice!
  2. Bush70
    Bush70 New Member
    Re: Onan fuel problem
    I would go with the carb. Might just be a piece of dirt in the needle. If not replace the needle and seat
    Good Luck
