Onan KY 3.6kva Microlite Adjustment
Discussion in 'General RVing' started by BjornAgain, Jul 20, 2007.
  1. BjornAgain
    BjornAgain New Member
    I require throttle adjustment procedure for a Onan 3.6kva Genset (06/99).
    The thottle arm which responds to generator load has 2 adjustment screws. One is for spring tensioning and the other is one arm itself.
    Another adjustment has a linkage to a 'box' attached to the exhaust via a flexible duct.
    The adjustment on the 'box' is via a dial with lock nut at a 2o'clock postion.
    Any help out there?
    Regards, Bjorn
  2. Guest
    Re: Onan KY 3.6kva Microlite Adjustment
    the linkage arm from the exhaust thingy u mentioned is the choke thermostat ,, and the one with the spring on it is the governer control,, the other should be for wide open throttle...
    Anyway what kinda prob u haveing with this set and why do u need a throttle adjustment ???? :)
    Is it hunting (up and down) ?? won't idle??? won't run at full power with load????
    Sorry just some random ques.... ;)
  3. BjornAgain
    The carby was overhauled - dismantled and reassembled. The choke thermostat and governor control was disconnected during this procedure.
    All runs smoothly until a load is applied eg aircon, and it labors and dies.
    Cheers Bjorn
  4. s.harrington
    When the carb was taken off were any of the settings adjustments changed? It really sounds more like a tune-up or fuel problem to me. Before you adjust anything test for no laod voltage. Should be between 128-130vac. If you have a frequency meter it chould run around 60-62 hz at no load. IF these are ok change your fuel filter and plugs.
