1989 Class A Cruise Master by Georgie Boy Built from a Chevy P-30 Chassis Right side (passenger) idler arm is worn. Large cast base bolted on the frame and double arm (1 for connecting rod and 1 for stabilizer). Was told there is a bushing kit available to repair it. New idler (from Chevy) runs $300.88 Anyone got a source for the kit? Last item needed to get it licensed. Any help would be appreciated. Thanks
Re: Parts Help Found my own answer. There is NO kit available. Bit the bullet and took the idler off the RV. Turns out there is on on both sides. Steering box is a separate piece. It is adjustable with a locking nut to keep it in place. A bit of clean-up on the threaded parts and now it is snug with no play. Problem solved.
