Please Help With Dolphin Fiberglass Roof Problem
Discussion in 'Class A / Diesel Pushers' started by John Hollaway, Jun 4, 2010.
  1. John Hollaway
    John Hollaway New Member
    In 2001 I bought a new National RV Dolphin. Where the fiberglass roof and sidewall meet National created a 90 degree radius (to make the vertical to horizontal transition) with thin fiberglass that was unsupported from beneath. Having apparently bumped into a tree branch somewhere, I now have an 18 inch long section of that radiused fiberglass that is cracked/creased and needs repaired. Can anyone recommend the correct repair procedure for this damage. Thanks.
    John Hollaway
    jhollaway@guilfordtwp.us
  2. C Nash
    Re: Please Help With Dolphin Fiberglass Roof Problem
    Welcome to the forum John. Might want to ck with a shop that specilizes in corvetts or a fiberglass boat repair shop. You probably could also repair it with etabond tape. Not sure if the spelling is correct on tape name or anything else I write :laugh: Fiberglass is a pretty easy repair if you know what you are doing. Good luck and keep us posted.
