Pop Up Roof Leaking
Discussion in 'RV Tips & Tricks' started by Steve-FLA, Aug 5, 2002.
  1. Steve-FLA
    Steve-FLA New Member
    I had my pop on the side of the house and I think my kids decided to use it for a jumping platform.
    I have a 1988 Jayco.
    The read end right in the middle where the seam is has been pushed down and is letting water inside.
    Any ideas on how to fix it? Can't afford to have it done professionally.
  2. rv wizard
    rv wizard New Member
    Pop Up Roof Leaking
    If it is fiberglass, I would clean the area from any wax and dirt and use 3M 5200. It is the best for fiberglass above or below the waterline!
    Mike & Amy - Fulltimers
    Ashley & Candi at school
    2000 Gulf Stream Scenic Crusier on Spartan M.M. 330 hp. & 6 spd. Allison
    #3 & #8 NASCAR
  3. Steve-FLA
    Pop Up Roof Leaking
    The outside roof is made of aluminum.
    the seam in the middle has some kind of rubber cover.
  4. rv wizard
    Pop Up Roof Leaking
    Sounds like the rubber is just a decorative molding. I would call the manufacturer and ask for suggestions as to the best way to repair.
    #3 & #8 NASCAR
