rodent protection for winter storage?
Discussion in 'RV Tips & Tricks' started by Dick R, Nov 25, 2013.
  1. Dick R
    Dick R Junior Member
    I am wondering what rv-er's are finding to be the best method of rodent protection. How about engine compartments. Just upgraded to a diesel pusher.
  2. rjf7g
    rjf7g Senior Member
    I fill all of the holes I can find with plain steel wool and place dryer sheets around to mask any food smells that may exist. If you put anything in your engine compartment, make sure you take it out before you hit the road!
  3. C Nash
    No sure cure that I have found. Radio on and lights all around the MH seems to help. I use the rope lights but ours is never in storage for long,
  4. erniee
    erniee Member
    moth balls
  5. C Nash
  6. erniee
    erniee Member
    scatter moth balls out under coach- when not in use
  7. DCLC
    DCLC Junior Member
    Used something called Shotgun Repels-All to keep critters out of the house when we're gone. Worked well so I started spraying it around my motorhome. Even my dog won't cross it. It's made to repel dogs, deer even armadillos.
  8. Shorty
    Shorty Senior Member
    I tried bounce sheets here as well...just didn't work too well...switched to moth balls but made my own holder for them
    Got some 3/4 " PVC...cut to 10 inches.Drilled a bunch of holes in the pipe and the inside diameter was just the right size to push the moth balls in
    took a zip ties and hung them up out of the way in the basement compartment and near the genset and such
    If the smell is too much...just tape up some of the holes
    Gonna check out the Shotgun Repels-All...need to train the dogs in 'other' areas...thanks DCLC
  9. Violet22251
    Violet22251 Junior Member
    We purchased a product called FRESH CAB at a local RV dealer. It is a botanical rodent repellant and has wprked very well for us. We too have tried moth balls and drier sheets to no avail. Their website is www.earth-kind.com.
  10. H2H1
    just keep ,moving and they can't catch up with you to get inside,, now that would be nice, but I know that is in practicable. So where can one get the shotgun repellant?
  11. C Nash
    Is the shotgun repellant 12, 20 or 410 guage.:D
  12. DCLC
    DCLC Junior Member
    Shotgun Repels-All can be had at Walmart and Lowe's. It's ok if the RV is stored away from the house. It stinks when first put down. Not for inside use.
  13. Steve H
    Steve H Senior Member
    I have had good luck with this product! I like the way it smells...DW, not so much!
  14. RVrobinandrich
    RVrobinandrich Junior Member
    Cover the tailpipe opening with a can, place numerous traps in the living space with all cabinet doors open, put dryer sheets everywhere, and hope for the best. I use at least a dozen mouse traps, figuring that I'll have a better chance of catching any and all varmints that invade my space. So far , the plan has worked well. In the spring I find one or two trapped mice, and a bunch of unused.
  15. RiverRunner
    RiverRunner New Member
    Happiness is hearing a trap snap shut in the middle of the night! Always gives me a smile.......
    Got that little bugger!
  16. RiverRunner
    We were told peppermint oil on cotton balls would repel mice. We went over to storage, put peppermint doused cottonballs all over the trailer......
    Next time we showed up....all the cotton balls were gone...I think they did it on purpose.....I felt used.....went back to traps. Problem solved.
  17. C Nash
    Traps and glue pads work. I know some say this is cruel but they don't belong in my RV
    LOL
