RV Storage.... please help
Discussion in 'General RVing' started by kate0680, Sep 5, 2006.
  1. kate0680
    kate0680 New Member
    Hi Everybody,
    My parents (aka tassiedevil on this forum) are travelling around the US at the moment and will be completing there 1st journey in their RV next week.
    I’m hoping somebody might be able to refer me to some RV storage places in California (Sacramento area). If not, where is a good source for finding storage other than the internet??.
    Also what type of preparation does an RV need being in storage for 10-12 months. Would you suggest outside or undercover storage? A rough quide of costs would be great too. Its a 28ft C class, if that’s any help.
    Here’s hoping somebody can help us out. Thanks in advance. Kate.
  2. kate0680
    kate0680 New Member
    RE: RV Storage.... please help
    Oh! and i forgot to ask, does anybody know the pros and cons of using a cover on an RV when in storage???
  3. hertig
    Re: RV Storage.... please help
    The pros is that it cuts down on bird crap, tree sap, dust and sun damage. The con is that if it flaps in the wind, it can be like sandpaper on the finish.
    Undercover is far better, but harder to find and more expensive.
    Clean out the black and gray tanks real well. Some people put a grill over the dump tube and leave the valves open. Clean and drain the fresh water tank and the water heater. Drain the water system as much as practical. Some people like to blow air through the system to get more water out. If it could get to freezing, fill the lines with non-toxic antifreeze.
    Turn off the propane at the main valve. I'd fill the tank first, but I don't know of any real down side of not doing that. Shut off the refridgerator and block the doors open a crack.
    Make sure the batteries are fully charged and full of water. Activate any battery disconnect switches or relays, or unless there are computers which need power to keep their memory, disconnect the wires from the batteries (labelling them to facilitate proper hook up next year). Set up some kind of trickle charge system. Options are solar panel, automatic generator start (this one gives me the willies) or a plug in system. Just plugging the unit into the wall may require monthly visits to replace any water boiled off in the batteries, depending on the type of batteries you have.
    If it is a diesel, it will be unhappy stored that long. It would be better if you could take it for a 100 mile jaunt every other month or so. If it is a diesel, make sure the tank is as full as practical to reduce condensation of water. Add anti-bacterial and other additives as appropriate. Gas will break down quickly and needs something like 'Sta-Bil', but I don't know how often you need to refresh it. It is possible that draining the fuel system would be the best option, but almost certainly would be a major pain.
    Make sure all automotive fluids are full and not too worn out. Plan to service them when you take it out of storage.
    Probably should visit every other month or so and run the generator for an hour under significant load (AC generally would be best).
    Wash the exterior real well to get any corrosive stuff off. Seal off anywhere that bugs could make their homes, particularly the vents for burners like the heater, fridge and water heater. Possibly air conditioner grill as well. Check all seals and do any roof maintenance which is called for by time or condition. Cover the glass with an external cover, particularly the windshield, to protect the glass and keep UV out of the interior (if not covered).
    Make sure the tires are not on a surface which could damage them. It would be best if you park it on plywood or plastic pads. It might be nice to block it up so the springs are not compressed and not all the weight is on the tires. Make sure that anything which has springs has the springs as relaxed as practical. Cover the tires to protect them from UV (if not covered storage).
  4. kate0680
    kate0680 New Member
    Thanks for the info hertig.
    Unfortunately my parents won't be able to monitor/visit the RV while in storage, cause they will be heading back to Tasmania, Australia next week. They then plan to return to the US in August 07.
    They have been travelling for the last 4 months around America and they have covered close to 10,000 miles. Would you suggest servicing the RV before it goes into storage or when they return for their trip next year?
    My parents don't have access to internet while travelling which is why i'm trying to do some research for them.
    Any help or info is much appreciated. :)
  5. hertig
    I'd go with the manufacturer's recommendation. If they are past the recommended service interval, have it done before storage. If they are before or at the recommended service interval, have it done after storage but before going anywhere.
    Even if they have the service done before storage, it may be useful to have the service done again after a year in storage, as the interval usually states x miles or y months...
  6. s.harrington
    If you can find it there, get covered storage. Some of the RV storage places have it for an extra fee.
