screen door
Discussion in 'RV Tips & Tricks' started by paws43tails, Aug 6, 2005.
  1. paws43tails
    paws43tails New Member
    anyone have any tips for making the plastic slide in the screen door that covers the doorhandle more efficient? mine keeps coming off track...
  2. Kirk
    screen door
    What I did was to stiffen ours by adding a finished wood strip to the inside of the recessed part. The reason that it pops out so easily is that it bows.
  3. paws43tails
    screen door
    thanks kirk! i will give it a try... what did you use to adhear it?
  4. Kirk
    screen door
    I mounted mine with stainless steel screws that have a wahser built into the screw head. I used four of them and they seem to do the job.
  5. RACINRYAN89
    RACINRYAN89 New Member
    Re: screen door
    where can i get that piece for my screen door the plastic piece that slides over the handle?
  6. LEN
    LEN Senior Member
    Re: screen door
    If your do it yourself Home Depot or lowes sells in sheets. If not do it yourself any glass shop can cut one to fit. In both cases you still need to fabricate a handle, maybe just a drawer pull.
  7. akjimny
    akjimny Senior Member
    Re: screen door
    You can get them at most RV stores or catalog order one.
