have a slight problem with my toilet. Water dosn't seem to want to shut off after flushing. I thought it might just be the ball in the water valve was sticking so I put some vasoline petroleum jelly around it. Didn't help. Still leaks. Guess I need to just purchase the water valve kit and install. Could it be something else? I know the ball inside the toilet that closes to keep water inside main bowl will close all the way. Seems to be a little rough in pushing the foot handle, but will flush , just won't shut off the water entirely (leaks just a little and will fill half the bowl in about two hours.
Should I just try and replace the water valve kit only? hard to do? just 2 screws? Never done it before. I do have the other part that controls the foot peddle (but I think you have to take the toilet off in order to install that piece, correct?)
