true grip and biger sway bar
Discussion in 'Class A / Diesel Pushers' started by didi, May 12, 2009.
  1. didi
    didi New Member
    i have a 2006 35 ft bounder that has a ford v10 motor in it im thinking about putting a bigger sway bar and adding tru grip to help keep it from rocking so much in the wind when i drive it camping world suggest this would make a big difference has any body done this and does it reaaly help? thanks
  2. Kettledinger
    Kettledinger New Member
    RE: true grip and biger sway bar
    I have a 2001 Winnebego Adventurer 37G on a 550 Ford Chassis and have the same problem. Have you tried new bigger better shocks?
  3. C Nash
    Re: true grip and biger sway bar
    Check tire pressure first and proper weight. Adding a bigger sway should help. Better shockes also help. I have steer safe on mine and it made a difference. Expect some sway but it should not be tiring or a fight to drive.
    just seen it was the 5/11 when the original post was made so guess i'm late:(
