TT tire clearence wheel well
Discussion in 'RV Tips & Tricks' started by dakotapicker, Mar 7, 2004.
  1. dakotapicker
    dakotapicker New Member
    Hello
    I am new to your site and camt to get some help.
    We have a 26 ft Dutchman TT. We have only 2-3 inches of travel room between the tires and the top of the wheel well. You can see were they have rubbed a few times. I was told to put the leaf spring on top of the axle. I wonder if coil helper springs would work, with a lot less work and time.
    Thanks in advance for the help.
    Paul
  2. Kirk
    Before you do that I suggest that you weigh the trailer and see if you are ovwer the GVWR for the trailer. If you are, then getting more clearance is only a small part of your problem.
