Uneaven Tire wear
Discussion in 'Old RVUSA Forum' started by Old Forum Post, Mar 12, 2001.
  1. Old Forum Post
    Old Forum Post Senior Member
    [Cesar] I have a cl c m/h and my front tires are worn out from the inside of both the front tires only. What is causing this uneaven wear. Im inflating my tires with the recommended PSI.
    Please advice.
    Thanks,
    Cesar
  2. Old Forum Post
    Uneaven Tire wear
    [Nash] What brand of M/H do you have? (ford Chev. Dodge). Sounds like you have a camber problem. A good alignment should take care of this problem. Be sure to leave the worn tires on so the techician can see the problem. Your tires will be leaning in at the top due to improper camber or something bent.
