Vehicle won't start
Discussion in 'Talkback' started by JADA, Aug 16, 2004.
  1. JADA
    JADA New Member
    I sure hope someone has some suggestions 'cause I am at a total loss. I have an 84 Flx 6v92 w/Allison 730. It has been running just fine and one day I parked it and shut it down to include shutting off both battery banks (12 & 24). A couple weeks later I return and turn on the batteries, set the start switch and when I hit the start button... nothing. It was dead. My gauge indicated 3v. I realived the 12v battery switch had been turned on prior to my arrival so I assumed someone had tampered with it and drained the start batteries.
    I put a 35amp charge on the battery and kicked it up to 200amps to try to start the bus and still nothing happened even though the gauge did go up to 14v.
    Is there a switch that disables the starting system if the bus is shut down while in gear and the air bleeds off? Is there a way to turn the system on and then tru to start it off the starter? I don't have a clue hot to get this thing to start as I don't know what the conditiuons were when it was shut down last if in fact someone did have it running.
    Should I try to put a charge on the 12v bank only? I can hear a click in the rear when the starter button is depressed. (speaking of depressed...) If anyone has any suggestions, please advise asap as I need to get the hbus started so I can take it in for some other mechanical work.
    Thank you,
    John Andersen III
    johna@radiks.net
  2. Darrell
    Darrell New Member
    Vehicle won't start
    Two things.
    1) a big deisel like that will require more than 200 amps to start..although I am a liitle puzzled as to why it didn't even attempt to start.
    2) if you left the batteries hooked into the system the charger was trying to charge your batteries (I assume you have at least 2 starting batteries)as well as turn over a heavy high compression motor.
    Suggestions
    I would leave the charger on for at least 12 hours or until the batteries come up to a 11+ volt charge, this should give you enough juice to turn the engine over.
    OR disconnect the batteries ground cables an use the start mode of your charger to power only the starter.
    This is a place to start. I am assuming you are using a proper voltage charger for your starting system when.
    Darrell
  3. Darrell
    Darrell New Member
    Vehicle won't start
    Two things.
    Suggestions
    Darrell
