water heater and refrig. wont start on gas
Discussion in 'General RVing' started by fordman, Sep 5, 2006.
  1. fordman
    fordman New Member
    i have a 96 coachman and we went camping this past weekend and i cannot get the water heater or frig. to light on gas using the battery. work ok on electric. the campground we were at did have a transformer blow while we were there could this have damaged my unit
  2. DL Rupper
    RE: water heater and refrig. wont start on gas
    Sounds more like a problem with your propane system. Have you checked your propane regulator for proper pressure? Did you look too see if you were getting a spark when the battery attempted to light the fridg?
  3. fordman
    fordman New Member
    my furnace will light ok and i can light the water heater and frig. manually
  4. DL Rupper
    I believe your furnace uses 12 v battery power to ignite. Therefore, that leaves the problem with the 12v igniters on the waterheater and fridge. Check and make sure the igniter gap is set correctly on both appliances. Take off the outside rear shield to the fridge and observe if you get a click & a spark when the gas control switch on the fridge is turned on. It sounds like a problem with the igniter/gap, ground, fuse or control board. If your 12v lights work in the RV, I doubt if the RV Campground power problem impacted your RV. A power surge would more than likely cause problems in you 115v A/C circuits.
  5. fordman
    fordman New Member
    Re: water heater and refrig. wont start on gas
    i tried it tonight when i got home and it worked.
