Water Heater Problem
Discussion in 'RV Tips & Tricks' started by winnie, Apr 29, 2007.
  1. winnie
    winnie New Member
    We're RV newbies, so there may be a simple solution to this...Our water heater seems to only be giving us a little bit of hot water. The temperature is fine, but there is very little hot water. My guess is that it's something to do with the valves. We have both the intake valve and the bypass valve open right now. Would the solution be as simple as turning off the bypass valve?
  2. Grandview Trailer Sa
    Re: Water Heater Problem
    Yes, it would be that simple. I get lots of calls every year about this also. You have to force the water through the heater. Water will take the path of least resistance.
  3. winnie
    winnie New Member
    thanks for the response. i figured it was something as easy as that, just wanted to double-check. glad to hear i'm not the only rookie whose asked the question. :blush:
