WATER PUMP
Discussion in 'Talkback' started by PETE JOYAL, Jun 19, 2004.
  1. PETE JOYAL
    PETE JOYAL New Member
    :laugh:
    I got a weird problem
    99 Pursuit 26 ft class A
    Water pump works fine until...the water heater ihas been on for several minutes. Then it seems like the thermal overload
    cuts off the pump. If heater and pump is turned off and after waiting from 3 to 20 mins. The pump will work again. It always works if water heater is off. Also, The control center panel lights all go out,
    while pump is out. Panel shows no lights for battery, water levels
    and no light for water pump and heater indicator.
    When pump cools off all works fine.
    Is there a thermal or other cutoff sensor in water heater
    that cuts out pump if there is no water in the heater when switch is turned on?? I dont get it.
    Any help greatly appreciated. Pete Joyal
