Hi there, new to RV's & need to winterize by this wknd. I have a 2009 Coachmen Freedom Vision. I understand the procedure, but I don't see the water heater to know if I need to do the by pass for it. I suspect it's behind the panel with a hot & a cold drain valve coming out of it. I need to do it right! Any advise is much appreciated
Also there is a short hose that trees off & is plugged from the "water in lines". Could I unplug this & use the pump to siphon the pink AF into the system thru it or should I go with the direct connect into the pump inlet? Could this short line be the factory installed hot water by pass? It's to the left of water works box. I don't have a manual to refer to. Should I have got 1 with the RV from the dealership? Thanks again for any help you have
