2024 Holiday Rambler Vacationer 33C
jeffburton
I have a HR Vacationer 33C. There are 2 outlets in the cargo area (and 2 that I've found inside) that are no longer working. These are the only 2 outlets in the cargo area. I presume they are on a GFCI circuit, but none of the non-working outlets I've found have a reset switch. No breakers have tripped, and no fuses are burnt. The RV is receiving power in other outlets. Does anyone have an idea where the reset switch might be for these outlets? Thanks so much!
jeffburton
Found the answer on another forum. "Check the outlets in the kitchen and bathroom". The bathroom outlet has a reset button, but hadn't thought to look there, as the other inside outlets I found not working were near the kitchen. Hope this helps someone else.
