Re: delamination
It depends on what caused the delam. If it was caused by a water leak of any kind neither the manufacturer or the dealer is resposible. If it is caused by a bad glue job or bad glue then you can usually get the manufacturer to pay. I have found that 90% of delamination on rigs I work on is caused by water. The other 10% is caused by desert heat. In the desert heat cases, Fleetwood relented and paid for the repairs as long as it was in the first 3 years(back when Fleetwood warranty was just 1 year). However when it comes to water damage they will not pay. As you take the siding off its real easy to tell. If its water, the luann underneath will be what is delaminating not the glue between the panels and the fiberglass. Since keeping your rig sealed is considered owner maintainace, the damage from water is your fault(read your warrant carefully).
