Electric Self Leveling Travel Trailer?
Heres some info I got back from the makers of the ultrapower II sold at Camping World,(POWER TWIN II STABILIZER Catalog Item # 22877 $584.10
Member Price Reg. $649.00) its not a automatic leveling unit and it appears you have to buy two, a "unit" for the front and a "unit" for the back if I am reading it right! I have gotten mixed responses from its ok to install to no travel tralier frames are not sturdy enough to handle it. I will be at the Nash factory this weekend so I will ask them. If I get any other info I will post it.
Ultrapower twin II
Adam,
1) controls, one toggle switch per jack leg, usually mounted in a protected area (storage area or inside the coach) no control pad, that is provided with the install.
2) operation, one switch per leg with control of up or down. Each leg functions independently, this allows for leveling
3) Location, mounted to the coach frame, with about 5 to 6" of jack below the frame. Usually bolted to frame, some weld to frame (not advised)
4) Power , this is a 12 volt system, it can be powered by the tow vehicle power source or and independent power supply on the coach.
5) system weight, you will be adding about 150 # per unit to the coach weight. (one jack has 2 legs, considered as one unit) if you install one front and back = 2 units
6) ground clearance, the jack leg has 30" of travel
7) installation manual, we are in the process of developing detailed CAD drawings and a comprehensive details for the installation, not complete as of this date.
we do have instructions available, but needs improvement.
Hope this helps,
Marv Troyer
Customer Service
1-800-860-7571
Now have gotten a reply back from "Power Plus" this is the only true electric auto level system I could find. Depending on your travel trailer ground clearance they have three different lifting jacks. Standard vertical, swing vertical & scissor lift. There website is
www.powerpluslevelers.com full list price for parts only is $3599.00 looks like I will stick to manually leveling for now!
