FORD F350 V10
Hi Chelse,
The 92 is not a P/S. I'm sure this would make a big difference. Mine seems underpowered, and there is a problem with the transmission. "OD" light flashes on and off when under load. (Wonder if Ford know this was going to happen--Owner's manual talks about it) It actually did this whether pulling the camper or not. Had dealer put it on the computer and he replaced the "speed sensor & speed control (?). Before they were replaced the only way to stop the light from flashing was disconnect the red wire from the battery for a few minutes, then it was okay for a day, a week or a month. No rhyme or reason to when it happened unless I was pulling a load. After the above was replaced, it seems to do fine except when I'm pulling. Now if it's flashing, I can, & it will stop flashing, but may start again in 5 minutes. When it is flashing, the pulling is much worse. Should change from 1st to 2nd at 15MPH but changes at 5. I was thinking of going to a F350 anyway and with the difference in cost between V10 and diesel, I'd certainly rather go with V10 if it's a good engine. Will only use the truck for pulling camper and don't plan on going above 10,000lbs or so. Camper now is 8800# dry.
This is the first deisel I've owned, so really don't know if I like them or not.
Thanks for your reply.
Happy camping
93 Dutchmen 330 5th. wheel
92 Ford F250 Ext. cab 7.3LD
