hi Allison Man
I have a 95 Monaco with a MD3060 w/touchpad. The thing that happens is every once in a while when trying to press into gear, a steady beep is audible and it just blinks without going into gear.
There was a power interuption once upon a time, (when the shutdown solenoid didnt shut the engine off but the electric did), but that has been fixed.
Is there a way to clear this issue and perhaps get the computer to reset on this? Or is this just a coincidence with the power issue and its a wire somewhere or something like that? I will check for codes tonight.
If we push enough buttons back and forth from N to D, N to R etc. eventually it will kick into gear and then run fine for quite a while. It only seems to do this once in a while. About every 6th start or so.
Any help is appreciated. Thanks Much!
