gray tank fix?
dragon
Junior Member
Hi
Just got back my Rv from getting a radiator crack brazed.... Got off real cheap, they removed it from RV and put is back... Just like new.
Anyhow that is not what I am worried about. There is a large crack around half of the end drain. I am taking it in this friday to get this fixed. What I am worried about is the gentlemen are going to "bondo?" the crack around the lever. Has anyone had or heard of this being done and does it hold up?
Re: gray tank fix?
can you just cut it out and have a new valve installed? I know that would be the best, but don't know about the bond do thing, so maybe other can give you a better point of view on it. Good luck
akjimny
Re: gray tank fix?
Karen, your gray tank is (probably) made of polyethylene plastic and there are adhesives made especially for plastic that will work, if applied correctly. If he is a competent repairman and knows this stuff, it should work.
However - Bondo will NOT work. Bondo is a 2 part body filler putty, used to fill in rusted car bodies. If he says "Bondo" double check what he is trying to use.
Good luck - post back and let us know how it goes. :) :) :)
Re: gray tank fix?
I'm with Jim on this. If its bondo as I know it will not be a good fix on plastic. It may be some kind of special bondo made for plastic he will be using. I just have never seen any
dragon
Junior Member
Re: gray tank fix?
Thank you for the information. I did not know that there was adhesives made especially for plastic. This does make me feel alittle better about it.
dfedora
Member
RE: gray tank fix?
There is a special welding technique that can be used for repairing polyethlene or even nylon tanks. It consist of a poly or nylon welding rod with a special heating gun with compressed air for repairing those materials.
There are adhesives out there but I wouldn't use it unless it is a hair- line crack its hard to get adhesives into the crack area to get a good adhesion. try to find someone to welded it.
good luck
