Re: help please!! New Freedom Express
It is possible it does not have a cable TV hookup. Or it might be in one of the compartments, most likely the one where the electrical hookup is. Most hook-ups tend to be on the left (driver's) side.
As for the slide, my first RV had a manual slide, and it was held in place with a quarter turn 'crank' lock on the bottom, and a couple of rubber tipped rods shoved between the slide and the wall at the top. If you didn't do this, it would slide in and out freely. If it is a powered slide, check that the 'manual override lock' is not engaged (to allow you to manually bring it in when the powered feature breaks). If it is not engaged, then there is something wrong with the slide; have the dealer fix it.
