help
Rex,
The way to know is to look in your truck. There should be a data plate near the driver's door, usually in the door frame (when door is open) that will list all of the weight limits. If it does not list the towing weight limit, the owner's manual will. Do not believe the advice of someone who is trying to sell you a trailer.
quote:They say it can pull 5,900lb. I would guess your 7,000lb is in the ball park.
That 1100# excess is nearly 20%. That would make for a pretty big ball park!
