Inside entry step
moberg
Junior Member
I'm new to the world of RV's. I just ripped out the carpet of my 1993 piece of heaven. I am going to replace it with vinyl. I'm wondering if there is a pre-formed plastic liner for the inside step. That seems a lot more functional and easy vs lining the vertical walls of that step with vinyl then putting metal trim along those edges. Any thoughts or help would be appreciated.
akjimny
Hi Moberg and welcome to the RUVSA Forum. Depending on what your 1993 piece of heaven is, there should be pre-formed steps that will fit. My 2007 Sunseekeer has a one-piece heavy vinyl "bucket" (for lack of a better term) just inside the door that froms a step into the motorhome. You might be able to find something to fit yours at an RV salvage yard. Check on-line and good luck.
Both of my steps are lined with a rubber mat. Which makes it very easy to clean. But my house batteries are under the second step also, so maybe that is why.
