Re: Newbie Needs Help
Gee Toy, the magic words. How well does my Dodge pull up hills. I've got the 2003 Dodge CTD 2500, 305 hp, 555 Ft lbs torque so its not quite as fast or as strong as the newer models, but I can tow my 12,000 lb 5th wheel up a 6% long, long grade at 70 miles per hour in 5th gear. I get 11.5 miles per gallon at 65 mph in 6th gear and if I slow down to 55 mph I can get about 12.5 mpg in 5th gear. Empty I get 23.5 mpg at 65 mph. This is a 3/4 ton, long bed, reg cab, 4x2 (light weight) Dodge Cummins Turbo Diesel. Oh, and did I say the Dodge CTD exhaust smoke smells good too. :bleh: :approve:
I might add I don't have a clue how well the new Dodge, Ford or GM diesels are doing. They switched to a bigger diesel engine with a more restrictive emissions control systems in the 2007/08 models. I wouldn't buy one until they get all the little bugs worked out. 2009/10.
Personally I would stay away from the older 6.0L Ford Power Strokes as they have had lots of trouble. The older Classic 07 GM Duramax/Allison is a good truck. The Duramax engine is probably not as reliable nor will it last as long as the Cummins, but good. The Dodge 05/06, 4 spd auto gets better mileage than the new 6 spd manual. However, the 03/04 older (NV 5600) 6 spd manual gets better mileage than the 4 spd auto. It's all in the gearing. The 2007 Classic GM Duramax has the most hp/torque.
:laugh:
