No Allison_man
WELCOME TO THE FORUM First off ,pull the dipstick for the transmission and look and smell the fluid. It should be fresh ,dark red in color,but clear, and it should not smell burnt. If its dirty/smells burnt then it was not serviced and needs to be. You say you have never driven a diesel before, it needs to run to warm up, depending on outside temp, 5 minutes to maybe as long as 30 minutes if temps are at or below freezing. This lets the fluids in the engine and transmission warm up and move thru each unit to lube components thru-out after setting and before taking off down the road. hope this helps LEE
