problem with lp tank
quote:Originally posted by jkill2001
well i got my first rv yesterday and i went to make sure that the lp was working and i unplugged the rv from the house and later to find out that the lp isn't running into the rv. what could be causing this. the guage is saying full and i know the dealer filled it before i got it. i also noticed there is a guage on the lp tank but there is a piece dangling that has 2 wires looks like a sensor that isn't hooked up to the tank and it looks to go to that guage. anyone have any idea or suggestions?
You did not say what the motorhome is but as the previous thread said the wires are for the LP gas detector inside your RV. when gas is detected inside, your detector will operate a shut off valve on your LP tank. There is a 1 amp fuse for the operation of your LP detector, mine was located up in front, in a bundle of wires on right hand side of firewall.The fuse was missing on my coach when I picked it up, small detail over looked, but a very important detail. KS-3740. Make sure you have a tech. that knows LP systems,check it out.---"007"
