roof air question
OctaveDr
hello! i am glad to find this forum...
my question is this: i have an older motorhome, dash air is needing an expensive repair...is it ok to run the roof air conditioning off the generator while i am traveling? thanks in advance!
larry
Gary B
roof air question
Hi OctaveDr, yes folks do it all the time, even when their dash is working and its hot. Just don't have your roof air on before you start the generator. Happy trails GB
OctaveDr
roof air question
thanks gary, i wonder what the difference in fuel consumption is compared to the dash air?
jerry fuhrman
roof air question
RV gen sets average 6/10ths of a gallon per hour, and yes it is
less than engine air requires. It does not have the cooling effect for driver and passenger, but its better than no air.
phillyg
roof air question
And if you're running the generator, you could set up a small fan to blow air towards the driver, too.
rv wizard
roof air question
Not only is it more economical to run the roof air; it is also good for the generator. Since a lot stay in campgrounds with full hookups the generator does not get a chance to run much. It is important to run the generator with at least 50% load for 2 hours a month. This is considered maintainance.
Mike, Amy, Ashley, Candi
2000 Gulf Stream Scenic Crusier on Spartan M.M. 330 hp. 6 spd. Allison
#3 & #8 NASCAR
