kevinfromwebb
Hey Yall, I've got a couple of install questions. I'm going to put a rack on top of my TT. I've got a Bobcat by Keystone which I believe has fiberglass and foam walls and roof with aluminum studs. Questions: 1) What's the best way to find the studs in the roof??? I was thinking about using just a regular stud finder, it says it will find wood or metal studs. 2) I'm going to be running some screws down to the studs thru the rubber roof,I was worried about either ripping the material or the threads of the screw catching and twisting the roof. I had thought about making a small cut in the roof where I would put the screws??? What do ya think??? 3) Any ideas on what kind of channel the studs is??? Didn't know if it was "I" or "T" shaped channel??? 4) Wonder how long a screw I will need to get a good bite on the stud??? Sorry bout the long post and thanks ahead of time for all help and thoughts... Kevin
