Sat Cable Hookup
Archer, the RG59 is usually OK for what you want to do because the length is pretty short. RG6 is basically the same coax, but better quality. That's pretty general, but effectivly true. There is one thing that could be a poblem however. If your cable connection has a splitter to send the signal to the fornt and the reat TVs then it will not work as the splitters won't pass the power from the receiver to power the LNB on the TV dish. But if you have only one TV, or if the cable comes to a selector switch first, and then to the two different TVs, you should be able to put the receiver between the selector switch and the cable input and it should work. That is what is done in most RVs that have a dish. You will need to bypass the dish receiver in order to use the cable connection when in an RV park that has it if you put the dish receiver in.
