satalite service
If you have dish network and a 311 box theres a reset on the front of the receiver , push and hold till the receiver goes off and comes back on, this will reset the receiver, then hit menu on the remote,that brings up a list , one should say "system setup" hit that, next list "install", next list "point dish", next page will give you your settings by zip code( you enter zip code from area you are in and it will give you the settings for the dish set up. (I'm not familier with your dish set up or how to set up your dish.Can you give it the settings (angle,skew,azmerth) and it will set up itself.)if so I think you have to scroll to the check switch button , and press that. When I set mine up, I called the local dish network store in my town, (privately owned) not the 800 number you called and I had the local guy set up my dish . I bought my dish (dish 500 pro, same as at home) from him and he came out and set up my 5er at the campground, and only charged me $35.00 labor. You may need to do that but I'm not sure. DONT CALL DISH NETWORK 800 # CALL YOUR LOCAL DISH NET INSTALLER (LOOK IN YOU PHONE BOOK) AND CALL THE LOCAL GUY HE CAN SET IT UP. HOPE THIS HELPS LEE
