Synthetic motor oils?
Hey, just a word to the wise... It's a big NO NO to mix Synthetic and conventional oils.. you can switch back and forth, change w/ Syn than next change w/ convent, but never mix the 2 together. They won't mix properly, and they will seperate. Also, I have started using Mobil1 in my car, and I'm not impressed with it's longlevity. My car has an OB computer that tells you the oil life. I bought it used w/6000miles, oil was just changed, drove it to about 10,500 before the indicator reached 40%life left. I changed w/ Mobil1 and now at 13,500 it's reading 65%. They say you can go as long as 15,000 miles, I WOULD NOT TRY IT!!!. I did notice an increase in fuel economy when I did first change, I don't know if it was a fresh oil change or mobil1, but I did notice it... I went from about 20.5 to about 22( once again it's all computerized) I've been in the auto market (Retail, service, and quick lube) for a total of about 16yrs. Keep in mind--- If you do use Mobil1, you still need to change the Oil Filter ever 3000 miles, even if you don't change the oil, and you'll need to top it off, once again you need to top it with Mobil1 (unless you use a conventional oil and then you'd be changing the oil also) One last note... If you do use Mobil1, then switch back to a conventional oil, you need to change the filter also....(You can never assume in today's time that everyone does that still..you'd be suprised at how many people I run into that just want the oil changed and not the filter[trying to save a buck]).. Jim
