I have a 1993 Tourmaster - Model 8391 - with a perplexing problem. There are 3 ceiling lights fed by a 20 amp fuse in the fuse bay. 1 lite is in ceiling by the stove. 1 lite is above the sink in bathroom, and 1 lite is in the bedroom ceiling. Each is the sunstream 12 volt florescent. The bedroom lite was totally bad so I disconnected it and ordered a new lite. In mean time - replaced the 20 amp fuse (which was blowing). Now - once replaced the fuse again I turned lites on and they work fine. Current draw was found to be just above 2 amps. However, the next time I turned the lites on - the fuse had blown once again.
Does anyone out there know if there are any other appliances or lites that may be running off this circuit (fuse block says "Ceiling Lites"). And - when fuse is blown - nothing else is NOT working.
Seems a little odd to me that there is a 20 amp fuse set up for just 3 lites that draw just over 1 amp each..
Have been fussing over this one for 2 months now. Thoughts and suggestions would help --- especially if anyone else out there is familiar with this model Tourmaster.
Bill
Bill
