Re: towing with four winds 31P
First of all, check the weight rating of the hitch on the unit. If the hitch will handle the 5K+ tow weight and whatever the pin weight of that set up is, then you need to check on the motorhome capabilities.
Ideally, you can go to a truck scale with the motorhome loaded for travel (including people) and get the total weight and the weight on each axel. Make sure that the rear axel weight is enough under the maximum rear axel weight that the pin weight of the trailer will not cause you to exceed this limit. Same is true of the Gross Vehicle Weight. Finally, subtract the actual weight of the motorhome from the CVWR (Combined Vehicle Weight Rating) and this will tell you the maximum trailer weight (including Harleys) which you can pull.
