Re: trailer or dolly which ones better
OK let get this straighten out.. Do you have a Class A, or Class C, or Class B RV? All of these are the one you drive. OR do you tow the Jayco TT behind a truck? If you tow this TT as Nash has stated it is not design to tow another vehicle. And in some states it might illegal to tow all in a row. However if it is a Class A.C.or B then you can tow the Dakota behind it. But you should check the owner manual a to see if it can be towed all wheels down. If it is a standard drive it might be possible however if it is a automatic, that may be a problem on both . Just adding my 2 cents :laugh:
